1 - 5 of 5 Posts
Yesterday while doing winter maintenance on my 37 I noticed my top motor mount was completely sheared off. It cracked on both sides just before it meets the top tube. Anyone have blueprints for the correct location of this bracket? I have a repop frame and the rear tank mounts dont align with the 37 tanks i plan on using someday (im running a chopper tank right now so it doesnt matter). If im going to redo it, id like it to be in the right place! Thanks!
If cracked just line the parts together and couple of tacks then grind out the crack. Or locate if off the top engine mount if the engine is installed.
Schematic Slope Map Line Electricity
This print is thanks to Gary. about the handbook
It shows flathead top hole location but not with the correct mount. Still doesn't give you the side to side location.
Note: the top frame mount is about a 1/8'' right of the top motor mount. Then spacer washers are used to adjust the fit.
1 - 5 of 5 Posts
