Just joined here, and I found one of my favorite topics to geek out on -- motorcycle electrics. Electrical engineering was my major in college before I dropped out (long story). And when I worked as a motorcycle mechanic in a former life Limey electrics were kind of my specialty.
Lots of people run capacitor/battery eliminators. Most people don't know why they work. This is pretty much it:
if you look at the charging system of a bike under an oscilliscope while you kick it through, you see that the voltage doesn't stay constant...it isn't a straight DC voltage, but more of a pulse DC. This is especially true of alternators because assuming your alternator is putting out an AC sine wave, it goes through the rectifier which essentially inverts the netgative half of the wave form.
So instead of the wave looking like a positive hump, and then a negative hump (google sine wave to see what I mean), it looks like a series of positive humps....going from zero volts to 12 to zero to 12.
NOw when the bike is running at normal RPM these occur so fast as to not matter, but at low RPM when kicking it's a big deal to your coils.
Coils fire because the volte drops, collapsing the magnetic field inside of them creating the spark. That's why they fire when the points open -- when electricity stops flowing.
Well, at low RPM voltage is dropping both when the points open and when the voltage out of the alternator drops to zero. No steady spark.
The Capacitor acts as a very fast charging/discharging battery. When the voltage goes up, it charges, when the voltage drops to zero, it dumps its charge essentially evening out the waveform and letting the coils build up a good spark.
So will it work with a particular bike? Triumphs and BSA, sure. ran one for years. I've even run them on electronic ignition and while you would think it wouldn't work it did.
I've verified they work on alternator shovels too, and generator pans. The only danger with a genny harley is that it could theorhetically lose polarization if it set to long -- But since you dont have a battery, the worst that would probably happen is screwing up your regulator. And you shouldn't let your bike sit.
Hope that helps, YMMV,
