I've been struggling for a while now with an issue I didn't manage to fix.
My juice rear drum is blocking after some miles (when it's getting hot I assume).
When the bike is in the garage it's working perfectly, same if I go around the block. Then if I go on longer ride it starts to block. Once it's blocking, if I release the purge it goes back to normal imediately.
I had this problem for a while now, so I changed the master cylinder, the wheel cylinder, even the brake lines, and of course I purged it many times and cleaned the circuit inside.
The only thing that aren't new now are the shoes and the springs inside which both looks in good condition to me.
Did this happened to someone here before?
Any suggestion or idea?
