1 - 3 of 3 Posts
I have seen some input on this, but can’t find anything again. i know about the fake neutral between 2nd and 3rd along with between 3rd and 4th, but it is really getting to where I constantly miss gears while shifting. I have a hand shift on it and need to feel my way through the detents to hopefully get it right. I thought there was an adjustment, but it doesn’t seem to do much.
thanks for the help if you’ve got some.
Are you using a hand shift top? Is it using 2243-36 or 2243-39 shift drum? If so first thing is to check the detent spring caps end is 2.25'' from the shift fork shaft. If that is right already, install a new ball 2251-36 and a new spring 2251-36A adjusting it to the 2.25''.
Thanks, Joe, I’ll have a look at it and see what I’ve got.
1 - 3 of 3 Posts
