1 - 3 of 3 Posts
68 generator shovel with s and s super e adndrews a cam and jims lifters, everything else is stock. What jets should I start with and settings on the air/fuel screw and accellerator pump should I go with. I had an andrews J grind and had to choke it down to nothin just to keep from foulin plugs, any help is greatly appreciated.
thanks
Dustin
thanks
Dustin
.028 int / .068 main to start, accellerator pump screw set so it just barely doesn't gasp when you rap the throttle, mixture screw turned 1-1/2 (CCW) out from fully seated.
You should own a .028 & .0295 int and .068 and .072 main for tuning.
1 - 3 of 3 Posts
