1 - 5 of 5 Posts
I got this wheel extra cheap and found a disk for it to mount on my Triumph build. But is it a Harley rear 16 inch wheel or is it a front? It looks like it’s off of a dyna
Wheel Automotive tire Tread Rim Synthetic rubber
, but I don’t know if it’s safe to put a sprocket on it or do I need to purchase a common rear rim?
40 spokes (cross 4).
Yes sprocket bolts are 3/8" Rotor bolts are 5/16 (mostly).
That appears to be a late EVO rear with a custom rotor.
I think these wheels are pretty much generic.
The big differences are, bearing style - Rotor ID - axle size. (My un-calibrated eye says the pic has a 3/4" axle, ball bearing, and a large rotor hole)
Some early stuff has goofy seals and spacers that can be swapped out if needed.
Check your axle and make sure you get a straight one, they are fairly soft.
Yes 3/4 axle is correct. Im wondering if this will be strong enough to mount a sprocket directly to it.
1 - 5 of 5 Posts
