IronHead its alive!!!
1502 Views 10 Replies 6 Participants Last post by  Antibilly
Well after a long long day I finally KICKED the bitch to life!! I installed the new drag pipes, finished the wring, removed and cleaned the tank. The major hold up of the days war what ever dip shit before me welded the rear pipe to the jug. fuck man theres No way in hell I could get that off with out removing the jug. so I cut the pipe back and left about 3 inches. slid the new pipe into it and clamped the fucker down. the upsweep on the pipes are not a perfect match now but look 100% better. on to the starting....after about 5 kicks I relized the switch wasnt on hahahah. so flipped her kicked her and the biggest flame blew out and then we knew we had spark!!! about 5 more kicks and she fired up and ran great!!!!! adjusted the carb to get a decent idle and away I went on the first test ride!! YEAAAAAAAAAAAAAAAAAAAAAA man whata ride Im so stoked the high fives were flying!!
MY QUETSION.
After the test ride we were adjusting the carb some more and the front pipe started glowing red. We shut her down and called it a night.
So what will cause only the front pipe to glow red???
pics to follow
1 - 11 of 11 Posts
Sounds like the timing is off.Or the carb is way lean.But since its the front pipe only I would guess timing.
Rob
that sounds kick ass man, I hope I can post a similar post soon.
congrats
Draglinkscc said:
MY QUESTION.
pics to follow
sounds like its a timing deal...too much retard lets the valve stay open too long
no popping around the carb at all? (would indicate an intake leak somewhere)
the retard part may be right hahaahahah Ill keep you all posted
you're too funny
exactly what kind of ignition are you running man?
****** said:
you're too funny
POINTS!!!
I also gotta replace the shift linkage. its a little short so the lever hits the primary case in the rear and the shifter is so far away from the foot peg I was shifting with my heel!
Draglinkscc said:
POINTS!!!
make sure and check that the advance weights and springs aint sloppy or stretched
happens a lot
pics with the new pipes and bars?? are they in another post somewhere else??
I dont want to hear all this I want a pic of the tool bag and mirrors.BABAHAHHAH
:D
Shoe
PS: and mount that tool bag down low on the down tubes now:p
:D
Shoe
later today Ill post pics of the tool bag!!!
1 - 11 of 11 Posts
