I find that if I eat ice cream the night before, I lose my morning shine.
Scotchbrite and steel wool will dull that chrome right up.
Brewdude had a descent article on the subject about 6 months ago in the Horse, goes into alot more detail than I'm able to type, you may want to check it out.like the Exil choppers. I have a chrome primary and rocker covers that the chrome is pitted. Can i strip the chrome to get that brushed aluminum look? Thanks guys
If you want to remove the chrome, muriatic acid 33 percent will take it off in a couple of minutes, then you can do what you want with the aluminum.like the Exil choppers. I have a chrome primary and rocker covers that the chrome is pitted. Can i strip the chrome to get that brushed aluminum look? Thanks guys
Does the muratic acid solution cause the chrome to flake off, of does it dissolve it off? Will this solution erode the aluminum in the time it takes to remove the chrome? I have a ton of old chrome to remove from some old Triumph engine covers, and am debating stripping v. replacing.If you want to remove the chrome, muriatic acid 33 percent will take it off in a couple of minutes, then you can do what you want with the aluminum.
Or you can just scotchbrite the chrome. But if it's pitted and flaking, you should probably strip it if you want a quality surface.
I've tried the muratic acid a couple of times...didn't work well only stained the shit out of the chrome, then I ended up with a bucket of "methel-ethel bad shit" to get rid ofDoes the muratic acid solution cause the chrome to flake off, of does it dissolve it off? Will this solution erode the aluminum in the time it takes to remove the chrome? I have a ton of old chrome to remove from some old Triumph engine covers, and am debating stripping v. replacing.
Thanks, Dan,
What Big John said. I can NEVER get the muratic acid trick to work worth a shit.
If you have a local plater and they like you, you can probably get covers stripped for $5 or $10 a pop. You have to remove everything from the covers because it won't be there when you get your stuff back. While the strip tank is busy dissolving the chrone, anything that doesn't have chrome on it will also be dissolved. I forgot and left the shift shaft bushing and washer in an outer cover last time I took stuff. It was like 90% gone when I got the cover back![]()
Ha ha! Took me a minute to get that!I usually ask my 8 year old a math question.
C
