1 - 8 of 8 Posts
There is usually an internal thread in the hub that you can screw a proper puller into to remove them. If not you may have to get creative with some other sort of puller or even resort to wedges and a brass drift...if you do, be careful to block behind the primary case to avoid cracking it.
There is a thread on the inside of it.
I will have to find that correct puller.
1 - 8 of 8 Posts
