Hugely inconvenient when you are by yourself but trust me, I thought about it.
Hugely inconvenient when you are by yourself but trust me, I thought about it.why not make a set of starter rollers like these, a buddy made them for me & didn't cost much, biggest cost was 8 bearings, 2 on each end, the rest was old scrap iron.....they worked well....
In my mind design, that I never built. It would look very similar to BobAsh's. My take would differ in that the rollers being fabed, and the motor would be a cheap HF 1800rpm motor. I would also use a foot control. A #35 chain and use a go kart slipper clutch as a soft start. I never made mine as I really never needed it, it was intended for drag bike starting.Really REALLY old post. Not even sure if BobAsh is active anymore. I'm trying to figure out what was used for a motor or see if anyone has a good suggestion for a motor or starter that would get the job done. I'd sure like to build one of these cuz they're so dang expensive.
It was kind of trial and error really. I did get lucky and it worked first time. I remember when I built that tube bender, tolerances were loose on the one I was copying so I did the same and that worked fine so I thought I would kind of do this the same and not have everything too tight together.A friend who has finished the Motorcycle Cannonball Run has one of those and recommends it. Good innovation there by you.
How did you copy the ratcheting action?
Hey Ratso, Im good thanks. Don't get on here as much as I used to because I have been working a lot on Jap stuff. I did do a resto on a BMW R100s recently, maybe I should have put that on here. I have a FB page of my stuff Kustom Choppers UK and there is a vid of the tyre tool on my YouTube ChannelReal good, Dan.
Where you keeping yourself these days?
