1 - 5 of 5 Posts
Need serious help with this one. I need a new stator and rotor for my '60 TR6 pre-unit. Want to go high output if possible.
-Does anyone know if a 54202299 welded rotor will work with my pre-unit?
-Thinking of running that with a 47194 stator (180 watt, 3-wire) if the rotor I mentioned will fit the shaft.
-OR will the stock rotor work with a 47194 stator (diameter??). If anyone has this stator could you possibly measure the I.D.?
-Has anyone run a 210 watt kit (stator, rotor, regulator) on their pre-unit?
Someone please tell me if that rotor will work. SOMEONE PLEASE HELP!!!
****** said:
they're the same diameter on units and pu's...ive swapped 'em before
no personal experience with the hi output but all that ive heard is positive
specially if you ride at night
When you're saying diameter are you referring to the inside diamter of the stator or the inside diameter of the rotor (shaft diameter)?
I've heard good stuff about H.O. also. Might as well make the change now.
1 - 5 of 5 Posts
