#1: In the pictures, one crank looks a lot thicker than the other. Is there a difference in 650 cranks? Since this is an SR (Street Racer) motor, was the crank lighter? What part of the crank is thicker? The whole thing or just the end? I have seen people machine down the end of a newer 650 crank to use for lack of a pre-68 crank.
#2: Will parts interchange between the TR6SR and a 1971 T-120 motor? I have a T-120 motor that was run without oil, so the bearings and rods are probably toasted, and the pistons are DEFINITELY toasted. I want to mix and match to keep it cheep. I am almost positive the parts won't interchange. I definitely know you can't use any of the head bolts.
#3: The cams and timing wheels are a little rusty. What's the best way to clean them up? Is it safe to run the cams with just a scuffing, or do they need to be reground/replaced? Get new ones. You can find them cheap on Ebay...i never trust parts that are rusty as shit.
