you mean WR not "racing WL." and those did not have a crossover that went into the right side as far as i know, also thy are more narrow.Of course they are garbage....but you know, someone's garbage is another's treasure, right ?
You mean racing WL or stock WL ?
i dont think the WR's ever had the fuel shut off valve above the filler cap, and they are noticeably skinnier than those. here http://www.wrdaytona.blogspot.com/ scroll about 1/4 down the page till you see the tank comparisons.Ok, the shift gate mounts should be under some bondo if they are original.
DId the WR had a oil tank under the seat? (I've seen that on some but don't know if they were all original)
