1 - 18 of 18 Posts
I have a 1976 harley 4-speed transmission. I am ready to lube it up now, and I keep hearing different options for lubricant.
Some folks have even recommended motor oil!?
Just wondered if there is an industry standard.....?
Also, exactly how full should I fill the case? To the top?
Thanks!
Mercman55
Harley used to recommend 60 wt., same as their engine oil. Now they have a special transmission fluid. I've used both and never had any trouble with either. Had a buddy that ran 90 wt. gear grease. He didn't have any trouble either. It takes 1 1/2 pints to fill one. It's in the service manual, they're nice to have in your reference library.
Atomic Custom
VA Rebel said:
2nd that Trent.
I use Amsoil.
I also ran 20-50w Amsoil in the case, primary, and trans of a 2003 Road King for 25,000 miles...
I thought I'd resurrect this thread as I have a question about my transmission.
My Enfield transmission currently leaks like a sieve, even after months of tearing apart, re-assembling, replacing seals, spacers....etc.
The new Enfields use only grease as a lubricant - can I run heavy/ hi temp/ standard (not sure which) grease to replace the gear oil I run now?
-Sheridan
-Sheridan
Some vintage bikes run semi-fluid grease in the transmissions.
http://www.morrislubricants.co.uk/scripts/prodList.asp?idCategory=141
I use Lucas 85/140 or 90/140 can't remember off hand which one it is. Mainly I use it because it's sold at the local Autozone. Thick enough not to leak all over the place. I also keep an old baby bottle right next to it so I can measure it out.
Sixball
Lately I've been using Bel Ray's Gear Saver 85W-140 in both the 4 and 5 speeds.
It's a semi-synthetic gear lube, and it has pretty good shear-resistance and kling properties.
I know Baker Drivetrain recommends Red Line 75W-250 for their trannys, and it's another good one, and a full synthetic.
I'll second the Bel-Ray. I've run it in my 4-speed, Evo chop for six years with no problems, including 3000+ miles out to New Mexico and back this summer.
1 - 18 of 18 Posts
