1 - 16 of 16 Posts
tabs you wont be needing on a trump thats a custom
i know you're scared but cut em anyway....they SUCK
(intervention took place by dr.Chuckopolis)
these 3 you wanna cut wide and then grind in...its thin up there
depending on the frontend you're running you can remove the neck stops
im leaving the nubs in hopes itll work on the HD im runnin'
leave these if you're keeping the stock tank...if not chop it
Discussion Starter · #2 ·
gr8 place to hide coils or mount crap...my tank'll hide it so im leaving it
you dont haveta
these 2 round dudes can be ground down
im keeping them for now for switch sites or seat post or something
the original swingarm mount can be cut and shaped as drawn
or you can leave it for a good "jockey shift" transfer spot
as Chuck added...you know its str8
the tit with the x's if you're anal
1 - 16 of 16 Posts
