1 - 20 of 23 Posts
· motorcycle enthusiast
My friend Justin has a broken rigid frame bike . He found the seat tube is broken and I am thinking he should put all his parts into a nice swingarm frame . He seems to entertain the idea , but is worried he would need to replace almost everything but the motor & trans to make it work .
here's the bike , so you can see what kind of shit's on it . . . my ponderance is what would you have to do to make that bike into a fancy duo glide style bike . Obviously rear shocks & different rear fender , axle , spacers . . . obvious stuff . BUT what about the tanks , oil tank , foot controls . I think those would all come right over to the new frame , especialy if you get the frame new and let them know what kind of shit you have already .
Anyhow . . . input ?
· Atomic Custom
Not a big swap, everything should fit just fine... Unless you are going to use a stock 4 speed FL frame, then you will have some work to do. If you are using an aftermarket frame for Evo, no sweat.
Trent...Now Mike has me thinking swingarm...that bastard! It will be the same 102 inch evo, 4 speed kicker set up.
· Atomic Custom
No problemo, I can accomodate you just fine.
· Atomic Custom
chicoman7 said:
Trent.. by looking at the pic mike posted what do you think...36 degrees?
Hard to tell from that angle, but I would guess 36.
swingarms cost more then rigid...lots more little trinkets...if your using late model tanks on a old shovel swingarm you will have to run a bracket set for those right off the bat...different rear fender...FL bracket for that two piston PM caliper he got on there...shit I have most of the stuff dude needs right here also...going to a swap meet in mid August so if he bites into the swingarm deal drop me a line I will hook ya up with parts cheap...later Chaz
=mike= said:
Okay, I'm not 100% on this, but I'll take a stab at it. I think the Evo motor may interfer with the seat post. The seat post on paughco rigid frames are recessed slightly to make clearence for the heads. I am pretty sure you can run a 5 speed tranny plate in a 4 speed frame without too much work. The flatside tanks from 85 on will not fit the 4 speed frames stock fatbob mounts.
A softail frame will except all of his stuff, that may be the way to go. Though as far as swingarm harleys go, you really can't beat the looks of the 4 speed frame.
No Evo is going to fit a drop seat frame period, if you get it to, you will not have electric start due to the drop seat...65-up frame will allow you to go with electric start but still won't fit a Evo without modifying the seat post and back bone, late model flat side tanks will fit a 4-speed frame barring you have the conversion to do such which I do have on hand....if you plan on two-up swingarm is the only way to go I do have compassion for my ole lady on back so I would never haul her around on a rigid...
Chaz and Von...The frame i have now is a 25 year old Santee. I had to modify it to accept the Evo motor ( I was running a panhead in that frame) I have now. Its a tight fit but its in there :) . Between me and mike we'll make it fit. Trust me lots of girls said it will never fit, yet it does hahaha!
In that case put a bitch'n drop seat frame on that EVO...Heh.heh...kick only 2 you wusss...heh..heh...:)
1 - 20 of 23 Posts
