1 - 20 of 252 Posts
Discussion Starter · #2 · (Edited)
FRC Smokin' Gun Frame - Sportster™ - $825
Sportster™ motors, 1986 - 2003 (excludes rubber mount)
  • 2010 Flyrite Choppers Smokin Gun rigid frame for Sportster™ -33° rake, no stretch in down tubes -(includes MSO)
  • Frames are set up to accept Sportster™ motors, 1986 - 2003 (exclude rubber mount)
  • Includes spacers for front motor mount
FRC Smokin' Gun Frame - Iron Head Sportster™ - $875
Sportster™ IRONHEAD motors, 1957 - 1981
  • Frames are set up to accept Sportster™ Ironhead motors, 1957 - 1981 (exclude rubber mount)
  • Includes spacers/plates for front motor mount
  • You will need to provide/fabricate your own top motor mount
Discussion Starter · #4 · (Edited)
FRC Loner Frame - Triumph™ - $849
unit construction Triumph™ 650
  • 2010 Flyrite Choppers 'Loner' rigid frame for Triumph™ --(includes MSO)
  • 29° rake, no stretch
  • comes with removable front motor mounts and (4) bolts
  • choice of neck size: 7/8" or 1" stem
  • pre 'oil-in-frame'
did you plan on doing a Smokin Gun for the 04-09 sporty's
Yes. Ive been looking for a frame and engine to get dimensions from and once I get one I can add it to my frame jig.
On another note, if you have one to loan us, I will give you the frame for FREE.
-Jason
Discussion Starter · #7 · (Edited)
The 'SS' Sportster Scorcher - Frame - $950
  • 2010 Flyrite Choppers SS' - Sportster Scorcher rigid frame -39° rake," stretch in back bone - 130 mm rear - (includes MSO)
Discussion Starter · #8 · (Edited)
The Drifter Frame - $925
For Big twin motors, pan head, shovel head, evo
  • 2010 Flyrite Choppers 'The Drifter' rigid frame -39° rake gooseneck, no stretch- 130 mm rear - (includes MSO)
  • Frames are set up to accept big twin motors, pan head, shovel head, evo.
  • This is the same frame used in The Drifter production models
FRC Risers - 2"
FRC's aluminum risers, featuring FRC's RiteTite™ clamping system are for 1" bars & bolt thru from the top.
Includes allen head bolts for the counter sunk top clamps.
These can be run as they are or polished, anodized or finished as desired.
$94/pair
Discussion Starter · #12 · (Edited)
FRC Aluminum Spool Hub - Inverted
FRC's narrow spool hub is reminiscent of vintage styles of old.
40 spoke, for 5/8" or ¾" axle.
Includes axle spacing sleeve.
$105.00
does flyrite make a frame to fit a 40's indian scout? or is there one that is close and could be doctored?
Discussion Starter · #15 · (Edited)
FRC Aluminum Spool Hub - Honey Pot
$105.00
Discussion Starter · #16 · (Edited)
FRC Aluminum Spool Hub - Ribbed
$105.00
Discussion Starter · #18 ·
All of the products listed here in our Jock Shop are made in house.
We have a full machine shop, aluminum casting facility and a 400 Ton Stamping Press.
1 - 20 of 252 Posts
