1 - 5 of 5 Posts
Hi guys!
I made a small wiring diagram for my 1947 Flathead 6v.
Can I wire like this? I´m using a magneto so dont need that to be wired. Just want the lights and the battery charging to work.
Do I need the "gen" lamp? I dont won´t one. Can I just leave it or should i replace it with a wire?
Many thanks in advance for the help.
The wiring is correct as far as what you want to do. You do not need the gen light, unless you want one. I believe I would put a fuse or breaker on the main battery feed, just to keep everything protected. but that is all I would change.
Perfect!
Ofcorse, I forgot to draw the fuse in.
But otherwise I can leave it as it is and just forget about the gen light.
That´s what I needed to hear, then I can finish the wiring tonight.
Thank you very much!
1 - 5 of 5 Posts
