the easy thing to do is put the stock rocker feed back on and see if that makes a difference. it could be just a coincidence.
Yes, don't be mistaken. He is correct about this. You don't restrict the oil to the rocker. It's the restriction of the oil return line that helps pump the oil to your rocker.The restrictor should be part of the oil return line that is part of the frame,
Not in my experience, the "restrictor" is the size of the hole drilled in the end of the return line about a quarter inch below where the line is braze welded shut.There is a little nob off of my OIF where the line meets the OIF frame near the oil return. I think thats is the restricter no?
The flow should be split 50/50, you need a 3 mm orifice/restriction on both the oil return and on the rocker feed.Yes, don't be mistaken. He is correct about this. You don't restrict the oil to the rocker. It's the restriction of the oil return line that helps pump the oil to your rocker.
Maybe your OIF restrictor was semi blocked thus pumping too much oil to the rocker.
