My buudy has been asked to make a skinny tank for a customer's '07 sporty and asked if I could look into replacing the stock pump with an external unit. I researched all the working parts and required regulator pressure. I found it to be within 38-45 psi. So I located an MSD universal external pump and adjustable regulator and am almost ready to pull the trigger.
Does anyone here have experience with this swap? The wiring seems pretty staight forward so I'm not worried abou that. I will be adding an inline schrader valve to check the appropriate pressure and an inline filter. I know it seems kinda dumb putting all this shit on the outside which was all once hidden, but isn't this what chopping is all about? I'm thinking about making a cool shroud/coil mount to cover all our hard work, hahaha.
