1 - 8 of 8 Posts
I'm building new pipes for my bsa and one of the pipes dips down about three inches from the ground, just in front of the rear tire. is this too low?
As long as they don't drag the ground when cornering , it should not be an issue. It would suck to put all the time in and learn that they scrape when you are leaning in a curve.
I just leaned it over, it has to go pretty far before it touches. I might try to rearrange it a bit.
my xs was real low, like 3" at the frame. biggest problem was speed bumps in parking lots. 9 out of 10 would knock the kickstand spring off.
1 - 8 of 8 Posts
