1 - 11 of 11 Posts
You could look at after market co's or check with the manufacture of your belt drive. I don't know if I would cut down the outer prinary yourself unless you have a good milling machine. And to have it done may cost more than buying one. Just my opinion.
Swap meets have them by the ton. Cutting down a primary cover is a waste of good parts, plus you have to cut the inner and outer to get what you are looking for. The machining would be more than the aftermarket one.
1 - 11 of 11 Posts
