I've been seeing more and more sketchy fabrication popping up so I thought i'd try and pass on some hard learned tips and observations. I'll skip over the obvious topic of the need for proper welding of any modification and focus instead on sound engineering design.
Motorcycles are subjected to some pretty extreme forces during riding from acceleration, braking, rough roads and unexpected course corrections etc. Add the weight of plus size riders and or passengers and things get even more critical.
Whenever a bike is modified either with bolt on parts or custom fabbed ones you need to make sure they will still take the strain nescessary for a safe ride. Footpegs should be strong enough to survive the strongest repeated kicking and bouncing you can deliver. I'm talking about jumping up and down on them with all the force you can muster. If they don't bend or break you are good to go.
The same goes for brake pedals, brake linkage, handlebars, passenger pegs, sissy bars, caliper mounts, fenders etc. If you can bust it off with your bare hands sitting in the driveway you don't need to be trusting your life to it on the road.
Be sure to use adequate hardware too. Use grade 8 on anything critical. Put loctite on everything. Make damn sure that sissybar/rear fender connection will take any strain it will ever see.
What it all boils down to is common sense and attention to details and safety. If you live as long as I have building and riding bikes you can hop up on your own soap box and try to pass something on to the next batch of youngin's
Of course if you choose to ignore this sage advice that's OK too. It will just provide a cheap source of used parts for the rest of us
