1 - 3 of 3 Posts
CityNiagara Falls
StateNY
Pricein add
Practically new. DD Oval speedo with sensor for 5/6 speed trans. I had it on a SC bike and took it off and put it in a box. I made the main loom to connect in the headlight it has dash indicaters for stock bikes or you can just run a speedo like i did both sensor and wire loom plug directly into unit ,connect hot and ground and you have a speedo you can calibrate. No mount or directions they went with the bike in a package of stuff when i sold it. You can find the PDF manual on DD site, Its still a currently sold item. You can also get sensors /speedo gears for most applications . Retail about $425. $250 shipped.
1 - 3 of 3 Posts
