Cowpie trans and horseshoe oil tank in a dropseat frame
4866 Views 8 Replies 4 Participants Last post by  gasketscraper
Is it possible without mods to the tank? I'm finding it very hard to get anywhere near the space needed to fit the tank over the cowpie with it's plate shifter top in there.
1 - 9 of 9 Posts
Are you using the right oil tank.
What primary
need more info or apic of primary side and tank.
What primary
It would be your standard 36-64 horseshoe. Going kick-only open-belt so no inner or outer primary to speak of, just an outer bearing support.
I'll get a pic over the weekend sometime.
Found a Paughco 748E which supposedly fits a dropseat frame with 79+ trans.
These tanks use the small kickstart Sportster battery, and fit rigid frames and 1958-1964 swingarm frames with aluminum primaries or 1979-up 4-speed transmissions with steel primaries. Use a Paughco #800E drain plug (sold separately). Measures 5 5/8"-tall x 8 5/8"-deep x 10"-wide. Battery plate is welded in place, and the compartment measures 5 3/8"-wide x 5 3/8"-deep.
Still have slight alignment issues...
I don't see the problem either. Looks like a few spacers on the rear mount and you're golden. Or am I missing something?
The main problem is the alignment of the tapped holes in the swingarm bosses and the holes in the tank bracketor, if i mount the bracket on the frame, then the alignment between the tank bracket holes on the bracket and the tank itself.
If I can get them to align, where would I find spacer material? Don't have access to a lathe.
That's why I dislike the aftermarket stuff. If you figure out the dimensions you can have someone fab some spacers up for you.
You don't need custom spacers. Take a measurement. Go to the hardware store look for a female pipe coupling 3/8ths or 1/2 " See how long they are. Close? Use a stainless washer as a shim if need be. If that doesn't work buy a short length of 1/2 pipe and cut to length in a chop saw. Dress it with a file. Think outside the box. Do you think all the bikers back in the 50's and 60's had instant access to a machine shop? It will be sanitary and only you need to know how you did it! Sometimes the coolest features are the result of necessity being the mother of invention.
1 - 9 of 9 Posts
