I am rebuilding a Betor 35mm front end. I have two of them and I am taking the best bits from each. One of them had two seals stacked in each slider the other had only one per slider. The shoulder that stops the seal is certainly deep enough for two seals stacked. What is correct? One set has solid fork caps and the other appears to have some type of vented caps. Can someone school me to the difference and the benefits of this vented type fork cap? Seems like the rebound is faster on the vented cap. Thanks,
Jakemon
