i know baker makes one. but would like to see if anyone has made one from swap meet parts.(buget parts), would like some ideas.thanks.
can you run a chain with oil, with the paugho or is it to cover belts only?Paughco and CCI both sell tin inner primaries that work with alternator cases and kick only. They use an early tin outer primary cover.
Nope, you can't run oil bath, just dry belt or total loss chain oiler like the 64 and earlier stock setup.can you run a chain with oil, with the paugho or is it to cover belts only?
