Yes it is.Is it 3.5" measured between the inner beads..?
It's more suited for a 4.50" then.. but isn't there a shop around your area who stocks both the 4.00 and the 4.50 tires..? If so,you can always ask him to trial mount them both so you can see which look you prefer..Yes it is.
Are they both on an 18x3.5 rim? If so, could you provide a pic?I have a 4.00 on my front and a 4.50 on the rear. They are VERY close to being the same size.
Rim Width Range Because tires have flexible sidewalls, a single tire size will fit on a variety of rim widths. A tire's rim width range identifies the narrowest to the widest rim widths that the tire is designed to fit. The width of the rim will influence the width of the tire. A tire mounted on a narrow rim would be "narrower" than if the same size tire was mounted on a wide rim. NOTE: Because the overall diameter of a steel belted radial is determined by the steel belts, there is little, if any, change to the overall diameter of the tire due to differences in rim width. The industry rule of thumb is that for every 1/2" change in rim width, the tire's section width will correspondingly change by approximately 2/10". |
