Get a good charge on the battery. Maybe have it load tested at a shop or even an auto shop to make sure it is good. Or just get a new one (preferably not one from Wally-Mart as they generally just suck, -the batteries and Wal-Mart both). I use AC Delco as I get them cheap and have had good luck with them. They also have a good warranty. Now that you're sure the battery is ok, test the alternator/generator output. voltmeter across the battery with the engine not running you should have bat. voltage= 12.? volts or so. Maybe 13. then run the bike and watch the meter it should start to increase as the engine speed increases over 2500 rpm. It should go into the high 14's Max. If it stays at bat. voltage you are not charging. If it contiues to climb higher than say 15v, you are over charging. Either condition will lead to battery failure. It has been my experience with rice burners that if the battery is not sufficiently charged it may crank ok but not start. I hope this is what you were looking for. MIKE.
