1 - 3 of 3 Posts
Guys - just rebuilding my 500 pre-unit triton and have a question about the cam timing.
The bike was built with E3134 cams inlet and exhaust. The bottom end is a T100 with an iron barrel and the head is a twin carb (I think from a T100R).
With these cams fitted I am guessing that I should not use the timing marks on the standard wheels but have to dial in different cam timing. Is there a 'standard' setting for moving the teeth timing on this convertion to E3134's?
Appreciat your help
Thanks
Jamie
You shoud degree the cams in using a dial indicator and a degree wheel. Measure where the intake and exhaust opens and closes using the various keyways (remember you can move a tooth as well as a whole keyway) and compare it to what the abovementioned data sheet is. When in doubt calculate lobe centers because cams will rarely if ever degree in exactly as on a manufacturers card. Yiou just gotta go with the best option.
1 - 3 of 3 Posts
