Sometimes the cover will get hung up on the shaft and the kicker shaft too. (I assume you are talking about the outer cover?) Not much to see under the outer one anyhow. The inner cover will get get hung up on the shift ratchet return mechanism, the ignition system and kick spring (if it hasn't already come off on it's own)....these things must be taken out of the way before taking the inner cover off.
