1 - 5 of 5 Posts
I have a 68 BSA A65 bobber and I have a question about the oil sump. I put oil in the reservoir tank and bring it up level. I can see in the tank when it is running that there is a good flow back to the tank and that the top end oil line has a good amount of oil going to the lifters. I took the sump plate off and no oil came out. I removed the valve cover and put @ 1/2 qt of oil and the oil started to raise the level in the reservoir tank. Is there not suppose to be oil staying in the crankcase area of the engine? Maybe a dumb question, but the manual didn't say drain the oil when you take the sump off.
you should have gotten a tea spoon or two of oil out the sump. The oil pick up tube don`t get every last drop. If it was totally dry, you got a issue. And it won't be long!
Fitting a magnetic drain plug to your BSA (or Triumph) is also a good idea, most Brit-bike shops have them.
1 - 5 of 5 Posts
