1 - 3 of 3 Posts
I should have taken more care before I removed, just wanted to ask when this is installed where on the plate is the spring loaded plunger sitting in with the transmission in neutral so I can reinstall all the gears? If there is anyway someone could dram in a arrow would be great. Thanks
That little notch on the middle of the lobe (about the 2-o-clock position) is the spot where the detent plunger sits in neutral.
272326
1 - 3 of 3 Posts
