So Ive been doing some work on my triumph frame for my first build. Ive been going through the frame and taking off the stock brackets, tabs etc etc.
I cut the two lugs off the steering neck as well as the fork stops. The lugs on the neck went through so I had to weld it in. I tryed my best to grind it back down flush and smooth, and it came out pretty nice, but when you step back and look at it, its a little wavy I suppose.
Id like it to look as close to perfect as possible, so I guess this is where you would use bondo or body fillers.
So my question is what should I use to clean it up, what are some good fillers, or tips and info.
Thanks for the help guys.
