DanDan said:
I know a guy that took pieces of landscape timbers (rounded 3"x4") cut them to about 18" to 24" long, nailed & bolted them together, 1" pipe threaded flange bolted to the top of the combo, then used a 4 ft long threaded pipe as the lever. Worked good on most of his bikes, if he needed to raise it up higher (dirt bikes) he would use 2x4's under it as cribbing. I used it for my sporty years ago.
The threaded pipe worked good incase you bent the pipe, just got a new one. You can even staple carpet to it if you want to save the paint on the frame.
