1 - 7 of 7 Posts
My buddy Charlie has done this with two of his Indians. Used to ride with him alot. Can't tell you any particulars, other than it worked. I guess it was cheaper than getting an original gennie.
TheAppleKnocker!
I have no experience with the SIE, or Bosch generators upon H-Ds, but I do remember the VW generators upon Indians.
There was a time when OEM replacements for Indian was a problem, although that's been cured in modern times ([email protected]).
A Bosch might as well be as rare as an Autolite, as the 'big box' auto parts retailers could only deliver me double-ended Microbus units, and they were dead in the box anyway.
That was nearly a decade ago.
So Indians have to be done right, or it is too damn expensive.
You can do anything you like with a harley of course.
But I hope you didn't spend much.
....Cotten
I ran one on a 45 back in the early 80s. The VW generator was better then the old 3 brush. New VW generators were also easier to find. If I remember correctly I had to run the VW regulator. My adapter was made by Cycle Specialties in Cleveland.
Hank
I worked in an auto salvage yard in the 70's and 80's and you could walk in and grab dozens of VW generators for 20 bucks a piece. Cheap and easy to find and they worked well. The Bosch regulator is one of my favorites.
1967 is the split year for VW pre and some 67's are 6 volt. After 67 12 volt.
1 - 7 of 7 Posts
