1 - 8 of 8 Posts
I'm lookin' for post style risers to run on a big twin 74 springer. I've found trees without the ears.....but who's makin' a post style riser to run like that?
Anybody?
tim
motorcycle enthusiast
I made some , but it's kind of caveman style . I just welded some cut off dogbones to the top clamp . Otherwise you can thread the tops of the back tubes and just use whatever kind of risers you want .
Hey Tim, I am looking for a pair myself and apparently there is some guy in Japan making them. A japanese speaking friend is trying to get the details for me, I will let you know mate.
Thanks Matt!!!
I know this is an old post, but I just ran across a setup Paughco sells to run T-bars on their springers. If it'll work with T-bars, it should work with almost any riser.
fine(machine thread) shouldered lock nut flip upside down,weld in top of rear tubes,then run whatever risers you want,usually on a small number of bolts if you go to a bolt and screw warehouse,like arrow or shamrock,they will give you a couple,so the cost is zip...see ya in March Tim.btw,I have decided to build a special bike for the Texas Chainlube Massacre,details to follow shortly
This Springer has 3/4 in. threaded rear legs......I'm gonna run dogbones...
Bitchin'!!! Let's see about gettin' everyone together for a Q........you be able to make it down?
tim
tim
would love to get together,when do you have in mind?I am still in the process of getting two bikes together but will be ready to roll as soon as one is tagged and runnin.Did you find a fender?I am still looking for you.My ford guru buddy is in New Mexico right now visiting family but when he returns I can get one for you fo sho.....lemme know
1 - 8 of 8 Posts
