1 - 14 of 14 Posts
I recently bought a front wheel that came off of a 67 shovel. I want to see if this will fit my current front drum brake assembly on my panhead. i understand that I may need a different axle, spacer ect since the hubs are different. Is there anything else that I might need.
Thanks, Tom
If you have only a complete 67-72 wheel, but a complete 48-66 front end, you need:
Axle
Sleeve
drum
1 bearing for the drum
Probably the center spacer for the wheel (unless u have it loose with your wheel)
later shovels had brake on right but it won't matter for what u want to do. Only the sliders and backing plate were diff.
not trying to jump in and steal what you got going here,i have a question and this seemed like the perfect time to ask,i got a 16" spoked wheel in great condition was told it was a 66 the drum is on the left,wondering about what a close guess of value would be.thanks for any input
· Banned
Sorry Diablo,
Didn't mean to slam you.
But this thread is about Hydra-Glide drums. So yes, BT springer drums and WLC are the same( so are Servi-Car mechanical rear and sidecar). But none of them fit Hydra-glide brakes of any year!
Robbie
Discussion Starter · #14 ·
My panhead is a conglomeration of parts. 1960 motor, 57 straightleg frame, and a hydraglide front end. The front rim was off of a 66-67 shovelhead. The front brake assembly however is a stock panhead. I wasn't sure if the drum and some of the hardware were compatable with the hub. But it sounds as though i got a few choices. What i may opt doing is to can the shovel wheel and go with an early star hub set up.
1 - 14 of 14 Posts
