Your float valve may be bad, or you may have something hung in the orifice. I would pull the bowl, turn the gas on, and watch the flow, then lift the float, and see if it shuts off. If not, you need a cleaning or a float valve. With good parts, the factory setting on the float, should be good enough to stop the leaking.
