Ok , I bought a BDL 1 1/2" belt drive w/ clutch for an electric start Shovel. As many of you know you cant take the alternator rotor off while the inner primary is on. (WTF?) Soooooo while aligning my belt I realize the spacer behind the rotor needs to go cause the belt rides up against it. That means remove starter/pull inner primary. Now I'm starting to think about losing the whole E start and inner all together. I HAVE NOT TOUCHED THE TRANS OR MOTOR mounting positions.
This belt drive uses no idler..it's figured out to be the correct length for stock primary chain replacement.
So in theory if i decide to loose the inner primary and I havent moved anything from stock distances I should be able to run WITHOUT a trans adjuster or will the lack of inner primary make things susceptible to moving around?
I think I just answered my own question...anyone run without one?
