1 - 5 of 5 Posts
I am trying to use my first belt drive for a Evo big twin from bdl for softail style setup. It is a 3 inch open drive. Now here is the question. I already had a hd closed stock primary drive system. Can I use the starter pinion gear assembly from my stock setup or do I have to buy the bdl pinion starter kit or is it one in the same? The outer starter ring looks about the same. Is there a tooth diffence in the pinion gear assembly with the bdl one or is it longer. Thanks
1 - 5 of 5 Posts
