41 - 49 of 49 Posts
Discussion Starter · #41 ·
Thunderbird,
Thank you.... Check PM
Cheers
L
Discussion Starter · #42 ·
Hey there,
I got the timing all sorted out and the bottom end is now completed.... working my way up.
A good friend of mine had an extra set of 750cc Morgo cylinders just needing honing, my local dealer didn't have standard bore pistons in stock so I ordered directly from Morgo in UK... They were a pleasure to work with, and as always top quality products... I got their oil pump as well.
Outerwear White Product Black Sleeve
272303
Gas Metal Auto part Machine Engineering
  • Like
Reactions: Goldy
Discussion Starter · #43 ·
I have a '67 Bonneville head I want to use on this motor... it was in fair condition but one of the over sized exhaust spigots was missing and threads stripped. I decided to have a go at machining an odd ball sized tap and spigot to match as I did not want to remove any more material from the head. It worked out well!
I also had to do a HeliCoil repair on all the rocker box screw threads. Now that I knew the head was good again I sent it off to get the valve seats redone. I got Norman Hybe valves with chrome stems, so modern gasoline will not be an issue.
Light Automotive tire Finger Household hardware Automotive exhaust
Automotive tire Machine tool Automotive design Metalworking Engineering
Automotive tire Light Motor vehicle Automotive design Bottle
That's really good, glad to see action in this thread again.
An acquaintance built a pretty remarkable T100 using a Daytona head that, as found, had very thick aluminum exhaust spigots welded in. He found they sequestered/gave away so much combustion heat that his stainless headers refused to turn color. If anybody's interested, the guy discusses this and a hell of a lot more in his build thread here:
"I sent it off to get the valve seats redone. I got Norman Hybe valves with chrome stems, so modern gasoline will not be an issue."
I get having the valve seats replaced , but the chrome stemmed valves, never heard of that. Can they mask off the valve so just the stem gets chromed, hows it work?.
Discussion Starter · #47 ·
I picked up a NOS 21" DID rim at a swap meet a few years ago... it was in great condition and perfect for this build. I had to breath some new life into a heavily corroded Jap hub I had in my parts hoarding pile, ended up having to "lick" off some stock to get rid of the pitting. It polished up well after this, new bearing and seals from All Balls and stainless spokes by Buchanan's of course.
Automotive tire Motor vehicle Bicycle part Gas Automotive wheel system
Automotive tire Wood Motor vehicle Automotive wheel system Machine
Automotive tire Bicycle part Motor vehicle Rim Machine tool
Wheel Tire Crankset Automotive tire Vehicle brake
Tire Wheel Bicycle tire Automotive tire Tread
  • Like
Reactions: HayMike
Discussion Starter · #48 ·
Hey Thunderbird,
I am not sure how the Norman Hyde people do it.... maybe chrome first then grid later. I referred to their website and it did not go into details. I was told they were the shit so I ran with that. o_O
L
Pssst. Hey. Hey Lester. Anybody home? Any progress on this fine project?
41 - 49 of 49 Posts
