1 - 16 of 16 Posts
Its where the oil pressure switch screws in the timing side cover. I am not wanting to use this switch so I just want to plug the hole. Is it something like 1/8" NPT? Anyone know?
Cheers Dan.
It's 1/8 British parallel pipe thread. If you thread an npt fitting in there the taper will crack the cover. Look next time your at a swap how many are cracked
Nope, its not that. I just bought a plug with that thread and it doesn't fit :(
D.
You can make a take off of the thread using body filler and a bit of care. Then you can measure the exact pitch of thread. What I gathered from the thread I posted, is that there are 3 possible pitches depending on the exact year of your side cover, 26, 27, 28. Determining the correct pitch will get you well on your way to finding the right fitting.
I was converting a pre unit timing cover to feed side oil filter and like everyone i thought it was 1/8 bsp and ran a 1/8 bsp tap down the hole , it removed a fair bit of metal so i doubt its bsp, but it works now.
i bought a plug for this and thought it was right..... i couldnt even get it to start in the hole. So since I changed my tranny pushrod to the ball bearing between type with new allen adjuster. I tried the old flathead adjuster screw, screwed right in.
1 - 16 of 16 Posts
