In the interest of clean bars, I want to convert an internal throttle to work as an internal twist clutch.
Does anyone have experience w/ this? Irish Rich?
Pretty sure Jason Evilfordcoupe has used a few, PM him.Tony Bones said:In the interest of clean bars, I want to convert an internal throttle to work as an internal twist clutch.
A Harley only set up for a long time, 1" bars only. With all the custom aftermarket companies out there now that may have changed. The grip sleve has a spiral grove internaly, the cable is attached to a slug with a stud and bushing (works like a roller to reduce friction). As you turn the sleve the roller rides it the grove producing the in and out motion. There are a couple more parts but that's the basics. Harley had left and right had units and they can still be found at swap meets and sometimes at Bent Bike (Lynnwood/Auburn) but there spendy now. The only downside to this set up is: If you fall down on the throttle side and the throttle grip contacts the ground, your foreward movement rotates the throttle to wide open. The outside cable throttle set ups were origonaly made for the racers to avoid just that problem.Crow said:Pretty sure Jason Evilfordcoupe has used a few, PM him.
Your right on that one it would rotate closed. I was in a m/c rodeo years ago and went down in the barrel race with a stock 52 I had at the time. I always thought it went wide open when it hit the dirt but I must have done it on the way off. I got the key off fairly quick but they sure sound bad when that happens.Irish Rich said:Are you SURE about this?
If you are rotating the throttle back towards you, and you hit the ground on the right side, wouldn't the forward motion CLOSE your throttle if it dragged on the ground? Wouldn't the throttle rotate in the same direction as your tire if it was "rolling" along the ground?
The "problem" with the Harley OEM internal throttles is that when you let go of them, they stay where they are, they don't return to close. There are no return springs. You have to manually close the throttle (and your spark advance grip). The spiral holds it where it is placed for both of them.
Also, Harley had two kinds of internal throttles. The earlier throttle spirals pushed the wire out of the housing when you opened up the throttle, and the later throttle spirals pulled the wire into the housing.
Damnit i always thought I had the cruise control option on the panhead!!!!!!!!!!Irish Rich said:The "problem" with the Harley OEM internal throttles is that when you let go of them, they stay where they are, they don't return to close. There are no return springs. You have to manually close the throttle (and your spark advance grip). The spiral holds it where it is placed for both of them.
Suicide clutch and jockey shiftTony Bones said:In the interest of clean bars
Ever ride a suicide shift bike w/ no front brake in Seattle? I snapped the drilled front brake lever on my Pan last weekend and had my first experience w/ suicide clutch/no front brake/hills. I have NO desire to do it again.tunglegubbin said:Suicide clutch and jockey shift![]()
doesnt exile sell one already done?Tony Bones said:Ever ride a suicide shift bike w/ no front brake in Seattle? I snapped the drilled front brake lever on my Pan last weekend and had my first experience w/ suicide clutch/no front brake/hills. I have NO desire to do it again.
I was thinking of using an actual aftermarket internal throttle, but reconfigured for opposite side operation. I have zero interest in a non-return, early Harley style unit.
replace the front brake lever ?Tony Bones said:Ever ride a suicide shift bike w/ no front brake in Seattle? I snapped the drilled front brake lever on my Pan last weekend and had my first experience w/ suicide clutch/no front brake/hills. I have NO desire to do it again.
I guess it depends on what you're used to.Irish Rich said:You know what's funny?
I talked to Russel in 2002 at Laughlin. He didn't have a spot, he was just cruising around.
I asked him how he liked his internal clutch (I saw it on his bike at No Love the November before), and he said:
"I like it, but I don't know if I'd be retailing these. They aren't for the general-type rider".
I did.=mike= said:replace the front brake lever ?
okTony Bones said:I did.
Yep... That's a cool bike.. He runs a jockey shifter/suicide clutch.. Right rear foot brake and a dual disc front brake which is being activated by a twist grip on the left side of the bars. I checked the bike out a couple times... He had the little master cylinder for the front brake hidden somewhere very nice... Can't really remember, I think it was under his tank or something..2 wheeler said:get in touch with paul cox you know the seat guy . he ran that set up on his bike (THE BERZERKER) if that spelling is correct . any way call gasoline alley he's cool he dont mind a ? now and then . just my2cents if needed.
