Status
Not open for further replies.
1 - 4 of 4 Posts
lookin into gettin my ironhead a pauchgo frame...
seeing what else will fit the sucker for bearing cups...
gonna run aftermarket 1" front end im pretty sure..
let me know what you guys have done.. THANKS
It uses stock Big Twin cups. You can use cups with internal stops or an external stop made on them. What you need depends on the front end you use.
Dragon said:
been hearing lots about these lately .. cups that let you run any bigtwin trees in ironhead frames ..
http://billetwerx.com/products.asp
I put a big twin front end on a late 70's Sportster. Even though the frame used a 1" stem frontend, I had to bore the inside of the neck out to clear the big twin stem.
Shouldn't make any difference on the Paughco frame, I think they use the Big Twin necks on most of their frames.
1 - 4 of 4 Posts
Status
