fastsporty said:It will work, but you need to find a S&S manifold, your stock is a CV slip fit and the S&S is a bolt on. The Super "B" is similar to the "E" minus the choke and accelerator pump. It was designed with constant RPM in mind. not very good if your leaving a stop light. It is better to mod your CV carb you will have better perfomance. I run a S&S on the sporty but if you want the best go with a mikuni. my 2 cents
fastsporty
fastsporty
Thanks!fastsporty said:It will work, but you need to find a S&S manifold, your stock is a CV slip fit and the S&S is a bolt on. The Super "B" is similar to the "E" minus the choke and accelerator pump. It was designed with constant RPM in mind. not very good if your leaving a stop light. It is better to mod your CV carb you will have better perfomance. I run a S&S on the sporty but if you want the best go with a mikuni. my 2 cents
fastsporty
let me guess you had drag pipes on that ironhead... S&S carbs and ironheads isn't the best combo, my experience is that it can be done but it just doesn't have the range a ironhead demands. if you flow a ironhead S&S will work great, but at stock you are either drowning it just to get the power you need (TT's case) or you have to lean it out so much it runs like shit. If any of you want to run a S&S in a ironhead and short pipes like a drag pipe, run a mikuni 38 if you can find one. Also for whatever reason a old bendix seems to work well too. I just don't have that much exp. with them.TRIUMPH TERROR said:I had a super b on a Iron head once awsome power when twistin the grip back but a couple laps thru town and you best be havin some spark plugs and a wrench cause it was a plug eater.
Shoe
