1 - 6 of 6 Posts
At 1/2 - 3/4 opening i'm getting inkling of pinking, especially getting on it up hills, a more gentle roll on and the motor shows no signs of pinking.
Plugs nice colour, Boyer fitted and was set to standard 38 BTDC, motor pulls like a train. I've retarded the ignition a deg ' or so and mebe slight improvement noted.
Question is to those in the know;
keep retarding ign' until prob' gone a long as power does not suffer?.
lift the needle a notch and set the ign' back to standard?.
Use a fuel additive?.
all of the above, tweaking is part of the fun?
Thanks
Thanks for the response, but:
new batt' fitted, and left on optimizer.
strobed at 38 deg BTDC.
the bike was re imported and has not had strip down , at least by me, when I pickeit up from po it would not pull over 65ish mph, messed about with jetting and got it this far.
at the mo' I'm as happy as a pig in sh*t with it, apart from this lightpinking , which i can 'ride around' but i don't really want to risk toasting the valves or pistons.
From comments I'm thinking is our pump fuel iffy? ( deffo' ), the other thing is could it have hotter / diffrent cams fitted? I guess I should fit a degree wheel and do some proper measuring to see what;s what.
Thanks for the input, sometimes it's whats needed to break out of fixed line of thinking / problem solving.
1 - 6 of 6 Posts
