Amal Help...again
1097 Views 4 Replies 4 Participants Last post by  Slipkid
today when i turned my throttle...SNAP!!! now i need a new cable. my question is that on my carb (concentric amal) on the needle there are 3 grooves for the neddle clip that holds it. which groove does it go back in?
1 - 5 of 5 Posts
Put needle clip in CENTER position to begin. After 50 miles or so. Look @ plugs to see if mixture is too rich(drop needle to top notch to lean out) or too lean raise needle to bottom notch. All engine/carb combos are DIFFERENT =No set numbers for tuning.
learn as much as you can about tuning amal carbs....you will need it.
http://www.oldbritts.com/amal_tun.html
I thought it said "anal" help.... Nevermind.:rolleyes:
1 - 5 of 5 Posts
