the choke has no reason to go all the way down to the bottom, when the slide is in the closed position there is nothing to choke, it's running on the idle circuit with almost all the air cut off.
Thanks Tony.the choke has no reason to go all the way down to the bottom, when the slide is in the closed position there is nothing to choke, it's running on the idle circuit with almost all the air cut off.
