1 - 15 of 15 Posts
I'm poishing the aluminum on my Ironhead. I usually use a cloth buffing wheel and I've found that using mothers on the final buffing works really well. My question is, what should I use as a solvent to remove the oxidation on the aluminum? Is there a solvent I can use when I'm finished that will slow down future oxidation? Thanks.
Don't know about the solvent issue but I've always used and loved Simichrome for the Bonnie's cases. Seemed to work the best.
Can you imagine my hardon when my work started buying Simichrome in gallon cans for the chrome polishing rolls? sadly I never scored a drop as all of the lowriders operating the machine had it....:)
I've always used various grits of sand paper from rougher to finer depending on the amount of oxidation on the aluminum. I do this by wet sanding with a mildly soapy water. I follow up by polishing with a buffing wheel and then Mothers Aluminum and Mag polish.
I have always wanted to try Simichrome though but never have for some weird reason ! :cool:
I have good luck using #0000 steel wool as an abrasive. Used almost every polish that I've found on the store shelfs or swaps and presently satisfied using Mothers Power Metal. Its for those Power Wheel deals.
WUZFUZ
If the piece is just oxidized and not scratched, I maybe use 600 grit wet, or dry, then buff it out with your wheel. I think they make a product called Zoop, that you coat the polished piece with that seals it. I never used a sealer on my stuff before. Just like to polish I guess.
I'm going to try some #0000 steel wool on the headlight bucket for my FLH. I want to get the oxidation off, but I don't want it to end up too polished looking (still want it to have some age). I though about cleaning it with Dawn to get all residue and oils off when I'm done then a light coating of wax. I'll be in the garage tonight so I'll let you know what I think of it tomorrow.
I posted earlier that I use steel wool for polishing and have never seen the afore mentioned rust form, I am very particular about the conditition of my alloy so I guess the extra effort in the polishing phase removes the steel wool particals.
WUZFUZ
use a wax to finish ,this will keep air from oxidizing the aluminum after you polish .its easier to apply wax than it is to keep polishing,I use any automotive wax .the engine heat does not affect it too bad.plus it kicks the polishing up a notch.
1 - 15 of 15 Posts
